Haha good vid Geoff! Kearn's r6 sure has some power to it. Zoid!!!! 7s is farking flying first time at wakey and you are right about temp being critical to grip, drops off like crazy when the sun goes in. Wakey is all pretty much block passing and the best passing maneuvers are in the scary corners, t1 - t2 (inside or outside), t3 - t4 (outside around t3 for t4 block), dive in t5. run from t6 to t8 (inside into fish hook), Around the outside at fishhook for t9. and braking into t10 left or right side hahaha. all make you clench up a bit and take lots of planning.
