Page 32 of 34 FirstFirst ... 2228293031323334 LastLast
Results 1,551 to 1,600 of 1681
Thread: What I did today...
  1. #1551
    Senior Member Simmo's Avatar
    May 2015
    Sydney
    137
    What tyre pressures are you running there Marshy?
    2013 Aprilia RSV4
    2005 Ducati 999s
  2. #1552
    And they're off and running....
    Quote Originally Posted by Little Mick View Post
    In standing actually lol
    Lol
    Quote Originally Posted by zoidberg View Post
    I knew there was a joke framed in that picture somewhere...
    HAHAHHAHAHAHAA!!! Boom tish.
  3. #1553
    Quote Originally Posted by Simmo View Post
    Yabbadabba dooo psi
  4. #1554
    Finally finished off a customer dooocati. It's come up alright, I reckon:
  5. #1555
    in a house
    1,007
    Nice one marshy
  6. #1556
    Looks great Nick, customer will be happy with that!
    You should of been handing out Superbike Source cards over the last 4 track days ... so many busted up bikes, in particular Doocati's to fix! Wonder how many will be permanently tracked now?
    You could get SU recovery to slip one of your cards (or better yet a small sticker) onto every damaged bike they recover?
  7. #1557
    Quote Originally Posted by Phat3R View Post
    Great idea!!!!
  8. #1558
    What I did today...
    Decided with the ape out of action for a little while that I'd be keeping the CBR as a2nd bike. So flushed the coolant with water, did an old and filter change and cleaned the air filter. I've had some fairings here for 7 or so mths so fitted them up to get her looking a bit neater
    Found out that the fan wasn't cutting in I let it get to 114 then shut it off. Pretty sure it should kick in at 103??? On that note is there any issues with hard wiring the fan to run whenever the ignition is on? Apart from draw on the battery is there a reason not to do it???
    Next it to Lock wire, but I'll need some lock wire pliers 1st. Does anyone stock then over the counter? Repco and super cheep didnt that know what I was talking about on the phone
    Cheers Luke
  9. #1559
    in a house
    1,007
    MCAS i think may
  10. #1560
    Preparing for a long overdue return from a unexpectedly long hiatus, in Feb hopefully.
    What's changed on track in 14mths?
    How quick are the groups lately?
  11. #1561
    MCAS i think may
    They did cheers
  12. #1562
    Admin Turbo's Avatar
    1,763
    Quote Originally Posted by Plumb View Post
    Cheers Luke
    Yiewww!! Fairings look a treat, Luke!!
    No probs about a manual fan switch, very common practice.
  13. #1563
    1,763
    Quote Originally Posted by senator8 View Post
    Glad to see you back, Rick!! Are you in for St George??
    First turn is a left
  14. #1564
    Moderator BoB's Avatar
    N.Beaches ,Sydney
    397
    Cheers Luke
    Cannot remember off the top of my head but I think it cuts in around 108 and turns off around 104 . Unplug the fan and put 12v to it and it should work , once you know its working ok you can hard wire the cbr 600 to the high beam switch as well as having the auto cut in .(ie use the 12v + from the high beam connected to the 12v + supply to the fan .
  15. #1565
    Cheers I actually got rid of the lights and running gear. ( might have them in a box of crap) But I'll test the fan tomorrow and make sure it's working 1st. If it is I might let it get a little hotter say 120 and see if it kicks in or not.
  16. #1566
    If it doesn't cut in by 110 you've got a problem. No need to cook it any further than that. Most jap bikes kick in at 103, but BoB knows cbr600s better than anyone, so take his word on the temp.
    Usually on 600s we wire in a manual fan switch, but there's no real reason you couldn't wire it to be 'always on' as you suggest. The reason road bikes are set to cut in over 100 degrees is to boil off any water/condensation in the oil, which isn't a problem we usually have here in Oz without snow and freezing overnight temps.
  17. #1567
    Wooooohoooooo!!! Be good to have you back, mate!
    Groups are the same... Totally depends on the day!
    Have you ridden since they resurfaced T4 and T9? It's grippier and slightly quicker, especially the exit of 9.
  18. #1568
    Cool cool. I'll check the fans operational and look at hard wiring it on permanently
  19. #1569
    N.Beaches ,Sydney
    397
    here you go
    http://www.tarmactalk.com/forum/show...0rr-fan-switch
    just updated the pics as the links didn't work anymore
  20. #1570
    here you go
    Legend !!!
  21. #1571
    N.Beaches ,Sydney
    397
    Legend !!!
    I will check the temps for the fan cut in off tomorrow and let you know
  22. #1572
    it will be good to catch up with you Rick!
  23. #1573
    Rick, the ram air ducts appear to have gone awol on the srad
  24. #1574
    Cheers Luke
    Torpedo7 have them, I got a set, easy to use, do what it says on the tin. Got them delivered in about 4 days when I ordered them.
    http://www.torpedo7.com.au/products/...r---wire-combo
  25. #1575
    N.Beaches ,Sydney
    397
    600rr 07-
    Fan comes on @ 104 deg and goes off when temp drops to around 102 deg
    digital temp displays "- -" below 34deg between 34 and 121 shows temp
    between 122 and 131 flashes the temp display and the high coolant temp warning light comes on (might want to stop the engine )
    Above 132 temp flashes "132" I think we might be in some trouble here..
  26. #1576
    600rr 07-
    Ta. Looks like I've got some fault finding to do.
  27. #1577
    N.Beaches ,Sydney
    397
    Remove the plug to the fan and put 12v to the fan , just to make sure the fan is working ok , and also check the voltage to the fan at the plug . If no voltage to the fan then check that the relay under the seat is working.
  28. #1578
    I'm chewing up this thread.... Whoops .
    Tested the fan working fine on 12v swapped the relay with a spare from the headlight but no joy. Don't have a miluti meter to test the relay atm so I'll have to get back to this in the new year.
  29. #1579
    Mmm maybe ride really fast that should provide ample airflow 😑
  30. #1580
    Quote Originally Posted by jaswib View Post
    This!!!
  31. #1581
    Sorted. Dose this mean I can keep going slow? Or have I been going fast enough to not need the fan.
    BoB cheers mate, I chucked a post on you fan switch thread as to what the issue was.
  32. #1582
    Torpedo7 have them
    Thanks Nath: I forgot how much I like stuff from Torpedo7!! Thanks for the link - I just ordered $300 worth of tools and bits and bobs I don't really need but would be nice to have. They have a massive sale on at the moment.... nearly everything is 40% off (and it's cheap to start with). Bargains!! Sale ends today.
  33. #1583
    No worries! Sorry I made you spend more money... But if I saved you 40% off $300, does that mean I get 40% of a V02? I worked it out with calculators and science, it's all pretty good.
    I actually need to grab one of those from you before end of the month, I will give you a buzz later next week.
  34. #1584
    You got me with your legal mumbo jumbo!
  35. #1585
    Mounted the new lie detector....
  36. #1586
    1,763
    Fuck yeah!!
    Looks ace!
  37. #1587
    That's a proper job Mr M 🏻
  38. #1588
    Senior Member Linden's Avatar
    Aug 2014
    Blue Mountains
    400
    Pulled stupid face while drinking Coffee in the Ducati Café in Rome IMG_2452.JPG
  39. #1589
    Senior Member Metal-Man's Avatar
    Aug 2014
    Sevo
    453
    finished fitting fairing ;-)
  40. #1590
    Quote Originally Posted by Metal-Man View Post
    Pics?!?!?
  41. #1591
    Aug 2014
    Sevo
    453
    Pics?!?!?
    nope ... not until after first TD ... can't fkn wait
    hurry up an get those forks sorted :p
  42. #1592
    in a house
    1,007
    Been working on a modification to a rear wheel to fit the Harris.....
    Had to machine the carrier, spacer, and boss/pocket so the carrier would move 8mm closer to the wheel. ( Wheel is off a CBR600)
    Note- bearings will be replaced for final assembly so didn't remove them for machining as they are required for mocking up etc...
    some candy for y'all....
    Cush drive rubbers will be customised as well
    Little Mick
  43. #1593
    That's very cool Mick, great work mate 🏻
  44. #1594
    Coooool!!
  45. #1595
    Little Mick
    Top work! How are you customising cush rubbers? As in making your own, or grinding down the current ones?
  46. #1596
    I put this lovely bit of titanium goodness on my bike. Sounds so much nicer than the micron I took off. And seems to pull harder.
    http://imgur.com/a/Hm6bj
  47. #1597
    Niiiiiiiiiice!!!
  48. #1598
    Now that's live a healthy looking bike... live lactobacillus and all
  49. #1599
    1,763
    Yiewww!! Looks great mate!
  50. #1600
    in a house
    1,007
    Cheers Guys
    for now will cut/ grind down originals, but once all complete, will most likely cast some rubber into a mould and look purty...
    next on the list though is a new rear calliper mounting bracket .....
    Mick
There are currently 307 users browsing this thread. (0 members and 307 guests)
