It must be a bleeding problem. The only thing that gives a long lever (while the bike is stationary) is fluid (or air in the fluid). If the bike is moving, it could be warped discs, sticking pistons, warped pad backing plates, out-of-round wheel, collapsed wheel bearings etc. But sitting still, there's air in the system somewhere, and it's almost certainly in the master cylinder. The Brembo RCS is difficult to bleed properly.
First question - was is a new bottle of fluid? What's the date on the bottle? Does the fluid look brand new? Maybe the fluid has contaminated in the bottle.
Then, move the M/C around (ie take it off the handlebar and physically turn it around in the air) to release any air bubbles, and allow them to travel up to the bleed nipple. Move it in such a way that you eventually end up with the bleed nipple at the highest point. Bleed again (a small amount of fluid is fine. Putting heaps of fluid through it with no air coming out is just a waste of fluid).
Then cable-tie the lever to the handlebar so the brakes are on. Don't go overboard with the pressure; just a moderate squeeze is fine. Leave overnight.
Check the lever in the morning.
