Your going better than me Lee. My engine let go yesterday so I'm out for FX.
Happy to help mate! Just bring that one I gave u back after u get urself a replacement!
Quick one re wrapping Lee. Stay with the good shit. Having wrapped my second set of fairings now the difference between a good vinyl wrap and a notso good (read cheap) are light years apart.
The 3m is so much more workable, washable and durable than any of the cheaper ones i've used.
And don't be tempted to use a blade except to cut the vinyl off the roll. The knifeless tape is the shiz once you get the hang of it.Really easy to get a good butt seam by using 2 strips of knifeless tape on each join.
Gets fucked, really Steve! That's no good at all.
Hope it's as miner as can be mate. If you need a hand, just ask mate.
Yep 3m all the way. A few people have said to stay away from the cheap shit.
Seen the knife less tape, never tried it, but if you say it's good, I will give it a go.
Thanks for the inside tips
It's a replacement Owen, a couple of decent holes in the cases. All good.
Just as screen shot video, but tell me what you guys think.
I think I got on the gas a bit early lost the back and over corrected ???? I pretty sure I diddent chop the throttle but not 100% sure it happened pretty quick
I over took a guy on the back straight prior so entered the corner a little narrower than my usual line. Not sure weather that was part of the issue?
Be nice im just a track learner
Looks like you got on the gas too much too soon on the small part of the tyre and chopped it else it would have low sided
Instead of starting a new thread, I thought I'd revive an old one.
What's the deal with camera mounts?
I've heard conflicting versions & the SU site is shit to navigate for clarification.
Will it pass if you mount a GoPro or similar externally (front number plate) and, can you use a suction cup mount?
No suction cup mounts. has to be an adhesive or clamping mount and it has to be secondary tethered to some thing decent... (zip ties work as a teather to a hole in something)
if you do both of those you will be fine... It has to be mounted before scrutineering so they can see its mounted properly.
Thanks for the info Carl.
I'm off to buy more adhesive mounts.
