Yeah it is, he tried to tell me that the price on the website was a special they had and he hasn't updated the page since. So on that note I just left it at that.
That's illegal!!
I guessed as much.. They only other place I have seen them for $149 is flea bay..
This is where I got mine http://www.ebay.com.au/itm/Liquid-Im...item27cfa01b1d
I have found them great to deal with and the best prices and aussie seller.
Is it really worth all the messing around with a group buy to save $3! Just buy one or two. You just saved $60 by the sounds of it - $139 posted
Hey $3 is still $3....For someone living on struggle street I can feed all four of us on $3.00.
Uploaded with ImageShack.us
I've just Got back from testing my new camera on my push bike...I might need some gloves fingers where cold...
Sorry senator for posting picture from your private collection.
Come on Baddie. No need to pretend its my pic. Your husband doesn't even visit this forum does he? So no need to worry mate.
Why don't you post a pic of you riding your motorbike? Or haven't got any?
Is that your new track bike baddie
Liquid Image Ego firmware update.. after purchasing my ego i wanted to use the wifi using the ipod as a screen and the liquid image app but it didnt work without the firmware upgrade so i used another app, action connect and this works if you dont want to use the liquid image app / firmware upgrade but no where near as good .
I did the following for the firmware upgrade.
Make sure when you unzip the file and save it on the sd card you rename it "firmware" with the file type .bin , dont have the version number included as the camera wont find the file to upload .
Firmware Version: 3.3.1.0
Date Posted: 20130-1-8
Major improvements since last release (v2.2.2.2)
1. Improve the remote browsing speed for camera contents.
2. Improve the image/video quality, typically indoor case.
3. Add Underwater mode (can be set through associated APP).
4. Charging speed through DC Adaptor is increased by twice.
5. LED indicator and Beep sound can be disable/enable from associated APP.
6. Support image flip mode (set through associated APP).
7. More Video resolution can be set through associated APP
8. Improve the speed of Wi-Fi coming to ready for operation (from 18s to now 9s)
9. Support more status parameters reported to associated APP, now APP can show the camera battery, Micro SD card status.
UPGRADE INSTRUCTIONS:
1. Ensure your battery is fully charged.
2. Connect your camera to your computer.
3. Make sure you Micro SD card is correctly formatted.
4. Download the file “firmware_V3310.zip” from the link: http://www.weltin.com.hk/support/liquid-image/
5. Unzip the downloaded “firmware.bin” and copy into the Micro SD root directory.
6. Disconnect the camera from the computer, the camera will auto power off
7. Press and hold “Shutter” button, then press “Power” button, release the two buttons when you see the words “Up” on the LCD screen.
8. The camera will automatically upgrade itself, after the process (normally within 1 minute), the camera will automatically shut down.
9. Restart the camera, wait till the Wi-Fi icon pop up (around 25s), then the camera will automatically restart by itself, it’s normal, after that, the camera is ready for use.
Notes: after upgrade, you may need to set up the camera Data/Time (through APP “Action Connect”) again, the APP will sort the camera contents according the DateTaken parameter, so it’s very important.
Me too, thanks BoB!!
And thanks for doing mine Bob
Here's my first play using some data overlay from the gps laptimer - It's race 3 from Saturday sprints at Wakefield
Nice video! Very crisp footage.
Dashware.
Next step is to get one of marshy's data logger dashes for the old girl.
Oooh that will be flash
im looking for some basic software (free) to edit some of my camera footage what do you recommend ?
just single at the moment , just want to chop the beginning and end off of the footage .
WMM is great; very easy to use. The only downside is that it doesn't preserve the 16:9 aspect ratio (or at least it never used to. Maybe it's improved?). For everything else, it's actually really good.
Check and update it first. Also, even if it shows in the preview panel, it takes quite a while to load the file. You can see if its loaded on the bar at the bottom. It won't play until 100%
where have we all mounted them ,, i currently run my go pro on the tree facing through screen .. looking for somewhere else for liquid image?
I got pretty creative down at Phillip Island. On the swingarm; under the tail looking at the shock and then off to either side, then at the rear tyre; triple clamps looking forward, then looking back up at me; the fairing just in front of the brake lever looking back at the throttle hand, and then looking forward (I had a gopro and a LIC taped together at one stage, facing in either direction, but they were a bit heavy for one mount and there was too much vibration.
The mounts on the LICs feel more secure than the gopro ones (the curved ones are very similar, but the LIC flat ones have twice the sticky area). Also they are noticeably lighter, so less vibration and less worry about shaking loose. I taped the plastic covers to the camera, then used the top hole to lockwire the camera to the bike (required for racing now) just in case.
Some of my camera angles from the weekend:
nice camera work marshy , it must have taken you another 5 mins to get ready , having to turn on all the cameras.
At least it gave me something to do in that horrible, eternal one-and-a-half minutes between the 2 minute siren (adrenalin really starts, but nothing to do to relieve it) and the 30 second siren (tyre-warmer removal time)!!
Guys check out the new steady cam mounts. Think there may be some issues when facing rear.
No...I'm not loving that and I'm not loving that! But I'm loving this!
I think it's Harry's lap timer app
Only for apple I think
Sorry, Hi. Harry's Laptimer it is. There is an Android version out now available for Android V4.0 onwards.
Check it out here.....http://www.gps-laptimer.de/Home.html
J.
I have to say after using those replay cameras that they work great.. shoot well and clear
only thing is that they have half the battery life of the gopros.. I suppose that is to be expected seeing that it is like 3 times smaller than the gopro!
There are currently 13 users browsing this thread. (0 members and 13 guests)
