Page 12 of 34 FirstFirst ... 2891011121314151622 ... LastLast
Results 551 to 600 of 1681
Thread: What I did today...
  1. #551
    Quote Originally Posted by Saturnalian View Post
    I also did this......
    Attachment 1062
    You bought Minions???
  2. #552
    Quote Originally Posted by Nelso View Post
    The engine went in as I bought it. I was told it was a runner, so I assumed it would be ok. Lesson learnt, next time strip the motor and rebuild it before putting it in.
    return it for warranty
  3. #553
    Copacbana
    739
    My son would be so proud of you right now.
    You got it in one !!!
  4. #554
    Senior Member Nelso's Avatar
    Mar 2013
    Wollongong
    391
    Quote Originally Posted by WETTY View Post
    Sadly there's no warranty on it as it was bought off a mate of a mate 15 moths ago. I had intended to rebuild it before putting it in, but when the other engine had issues, I just put it in without touching it.
  5. #555
    Maybe you can build 1 from the broken 2
    Get yaself a manual and hook in
  6. #556
    What are the intake lengths for the bottom and top bits Jamie? its funny how they just turn on the extension pieces for the uppers, so simple.
  7. #557
    Keeping an eye on the oil temp hotness
  8. #558
    Quote Originally Posted by Kris View Post
    Oooo, fancy!! That would be unreal data to have. And would edjumacate people better about how water temp does not equal oil temp. "Yeah, I warmed my bike up to 60 degrees on the dash first thing in the morning, then gave it the berries!" Oh, good one; that will promote engine longevity......
    It'd be great if you could share the results
  9. #559
    Indeed! water does not equal oil :P
    Will share the results if you're interested - earlier RSV4 engines in SBK form had issues with oil foaming and extreme heat so will be monitoring this closely...
  10. #560
    It would be great to know.
    Interestingly the 09 Factory runs very hot compared to the 2013 R. I haven't yet worked out why, as the R feels slightly more powerful (bugger all in it though, now I've got the Race map ECU in the 09). The R will sit at 86 all day, even in 40 degree heat, whereas the 09 is at 98-100. Odd. The radiator in the R is the massively bent and straightened one, so cooling would be way less. The 09 rad is in mint condition.
  11. #561
    The reason is because of the engine casing.
    In 2012, they revised the engine casing and changed the bearings over to roller bearing, they basically enlarged the breathing holes at the bottom of the cylinder and also enlarged the crankcase breathing holes in the bottom of the case walls, in combination with the new roller bearings on the balancing shaft etc this reduced friction and reduced heat. The new cases allow the engine to breath far better which increased power by 4hp. This is why the earlier engines in SBK form used to overheat the oil and foam it.
    Ive got photos of both types of casings somewhere.
    You can modify 09/10/11 casing to bring it up to 2013 specs with new roller bearings and a dremel to open up the ports.
  12. #562
    Moderator Baddie's Avatar
    Glenmore Park
    352
    Sounds like a shit loads of work for 4hp...Easy fix... buy a Kawa.....Runs cool....and run straight past RSV4's
    image upload
  13. #563
    He's still faster than you with less power :P
    09 vs 13 engine - in 4 years its natural to see a number of improvements, especially because the 09 was the first year of sale.
    Compare the 13 ZX10 motor to the 09 ZX10 motor....
  14. #564
    Quote Originally Posted by Baddie View Post
    Sold trackie....too many issues.....headwork = overheating.
    But loved the kawa handling brought another... Ã**½Ã*²šÃ**½Ã*²šÃ**½Ã*²šÃ**½Ã*²š
  15. #565
    Yeah , Nice work Rick.
  16. #566
    hahahhaaha
  17. #567
    Quote Originally Posted by senator8 View Post
    nothing escapes you :P
  18. #568
    You could with your times
    I can't ride at the moment so can only read about riding
  19. #569
  20. #570
    Not so much what i did today, but yesterday... an early mark from work allowed me to go to my tiny lock up/workshop to put on new levers, keyless fuel cap, size up rain light bracketry, size up lap timer bracketry, put in some new dzus fasteners on and general milling about and fiddling with new tools and parts. Mainly drooling and day dreaming over the recent Kurveygirl package with vesrah!
    Not much i know but gave me my fix.
  21. #571
    Admin Turbo's Avatar
    1,763
    Quote Originally Posted by James_ View Post
    Pics!!
    Must be cold working out in that polar vortex tho?!
  22. #572
    FKN FREEZING. about 4 degrees, plus windchill. I also put plugs in belly pan. Lost feeling in fingers trying to squeeze grommet in.
    Ill be posting a whole bunch in my uk thread when I can be bothered to d/l off andriod.
  23. #573
    The Floppy Turtle's Avatar
    Dec 2014
    Rouse Hill
    87
    Quote Originally Posted by Phat3R View Post
    NFI where I'd get those. See that's why I'll just have to take old girl to an expert. Might take her for a revival trip to Wetty's when he's dun fishin and lounging in the sun.
    What year and size is the girl? Can use mine for measurements if it's around same era? K4 600.
    2016 Kawasaki ZX10R Winter Edition
  24. #574
    022.JPGThe sub frame on this thing has been off to the right ever since I have owned it. .With the seat unit on it's not quite as bad but the frame it self is 12mm off centre . So off to Smithfield at some stage this week. I pulled it off completely and checked the lugs for damage and all is good so a good chance to detail the back area and back on for straightening.
  25. #575
    he needs it on the bike to straighten it bagger
  26. #576
    Yeah ,I just took it off to check the frame and lugs and give it a clean ,it's back now .So your still alive ?
  27. #577
    yes , just
  28. #578
    Quote Originally Posted by Turtle View Post
    Thx Turtle ... K1 600 ... don't worry ... she's been flipped quite a few times by me, so I think she's due a professional straightening from Laurie.
  29. #579
    Senior Member dan's Avatar
    Jun 2013
    Sydney
    1,298
    Fx retro round 1 will be here before you know it!
  30. #580
  31. #581
    Niiiiice!!
  32. #582
    Niiiiice!!
    It's what I did today
    Not what I bought for way too much coin and paid someone to install it/em !!!
  33. #583
    Dec 2014
    Rouse Hill
    87
    I see we've found TT's token commie.
  34. #584
    I got some rust cut out , not from the bike , from the top of my head . Five stiches later i'm still good looking. Wear your hats kiddies.
  35. #585
    Shit mate; hope it doesn't slow you down any. Hang on, yes I do! Sorry about that
  36. #586
    Should be lighter now.
  37. #587
    Quote Originally Posted by stevem View Post
    i'll meet you for breaky on the fri b4 the race . triple bacon egg roll for the bagger .
    you survived the old road in the 80's you will be here till ever bagger
  38. #588
    bull shit detector you have found
  39. #589
    1,763
    Shiiit! That from an old injury?
    hope you're ok mate.
  40. #590
    Na, all good mate, just keeping on top of things. Looking forward to breakfast on Friday though Wetty
  41. #591
    Still building..YOLO.
    WSBK Ohlins RSP40 and billet linkage, Gas canister and potentiometer
    WSBK auto blip shift potentiometer, MotoGP ART dash and Front Brake pressure sensor
    Aprilia Racing Shift poteniometer
  42. #592
    sounds like seriously $$$$ in those pictures...
  43. #593
    Well you cannot take it with you, & he who dies with the most toys wins nice work
  44. #594
    Quote Originally Posted by Leezx10r View Post
    most toys. not most expensive toy
  45. #595
    Both I think hehe
  46. #596
    1,763
    Awesome!! Very keen to hear how the auto-blipping goes...
  47. #597
  48. #598
    1,763
    Braaaaap!! Love it!!
  49. #599
    How the heck did you get your hands on a RSP40?!? And when do the TRVP25 forks arrive?
  50. #600
    hahaha :P TRVP25 ... maybe, but not now. That would mean new clamps, new brake calipers, custom axle yada yada... I just had some Ktech SSRKs put into my current forks and I really haven't been able to fault the forks or their feel with the IMA clamps.
There are currently 100 users browsing this thread. (0 members and 100 guests)
