What tyre pressures are you running there Marshy?
2013 Aprilia RSV4
2005 Ducati 999s
Finally finished off a customer dooocati. It's come up alright, I reckon:
Nice one marshy
Looks great Nick, customer will be happy with that!
You should of been handing out Superbike Source cards over the last 4 track days ... so many busted up bikes, in particular Doocati's to fix! Wonder how many will be permanently tracked now?
You could get SU recovery to slip one of your cards (or better yet a small sticker) onto every damaged bike they recover?
Decided with the ape out of action for a little while that I'd be keeping the CBR as a2nd bike. So flushed the coolant with water, did an old and filter change and cleaned the air filter. I've had some fairings here for 7 or so mths so fitted them up to get her looking a bit neater![]()
Found out that the fan wasn't cutting in I let it get to 114 then shut it off. Pretty sure it should kick in at 103??? On that note is there any issues with hard wiring the fan to run whenever the ignition is on? Apart from draw on the battery is there a reason not to do it???
Next it to Lock wire, but I'll need some lock wire pliers 1st. Does anyone stock then over the counter? Repco and super cheep didnt that know what I was talking about on the phone
Cheers Luke
MCAS i think may
Preparing for a long overdue return from a unexpectedly long hiatus, in Feb hopefully.
What's changed on track in 14mths?
How quick are the groups lately?
Cannot remember off the top of my head but I think it cuts in around 108 and turns off around 104 . Unplug the fan and put 12v to it and it should work , once you know its working ok you can hard wire the cbr 600 to the high beam switch as well as having the auto cut in .(ie use the 12v + from the high beam connected to the 12v + supply to the fan .
If it doesn't cut in by 110 you've got a problem. No need to cook it any further than that. Most jap bikes kick in at 103, but BoB knows cbr600s better than anyone, so take his word on the temp.
Usually on 600s we wire in a manual fan switch, but there's no real reason you couldn't wire it to be 'always on' as you suggest. The reason road bikes are set to cut in over 100 degrees is to boil off any water/condensation in the oil, which isn't a problem we usually have here in Oz without snow and freezing overnight temps.
here you go
http://www.tarmactalk.com/forum/show...0rr-fan-switch
just updated the pics as the links didn't work anymore
Rick, the ram air ducts appear to have gone awol on the srad![]()
Torpedo7 have them, I got a set, easy to use, do what it says on the tin. Got them delivered in about 4 days when I ordered them.
http://www.torpedo7.com.au/products/...r---wire-combo
600rr 07-
Fan comes on @ 104 deg and goes off when temp drops to around 102 deg
digital temp displays "- -" below 34deg between 34 and 121 shows temp
between 122 and 131 flashes the temp display and the high coolant temp warning light comes on (might want to stop the engine )
Above 132 temp flashes "132" I think we might be in some trouble here..
Sorted. Dose this mean I can keep going slow? Or have I been going fast enough to not need the fan.![]()
BoB cheers mate, I chucked a post on you fan switch thread as to what the issue was.
Thanks Nath: I forgot how much I like stuff from Torpedo7!! Thanks for the link - I just ordered $300 worth of tools and bits and bobs I don't really need but would be nice to have. They have a massive sale on at the moment.... nearly everything is 40% off (and it's cheap to start with). Bargains!! Sale ends today.
No worries! Sorry I made you spend more money... But if I saved you 40% off $300, does that mean I get 40% of a V02?I worked it out with calculators and science, it's all pretty good.
I actually need to grab one of those from you before end of the month, I will give you a buzz later next week.
Mounted the new lie detector....
Pulled stupid face while drinking Coffee in the Ducati Café in Rome IMG_2452.JPG
finished fitting fairing ;-)
Been working on a modification to a rear wheel to fit the Harris.....
Had to machine the carrier, spacer, and boss/pocket so the carrier would move 8mm closer to the wheel. ( Wheel is off a CBR600)
Note- bearings will be replaced for final assembly so didn't remove them for machining as they are required for mocking up etc...
some candy for y'all....
Cush drive rubbers will be customised as well
Little Mick
Coooool!!![]()
I put this lovely bit of titanium goodness on my bike. Sounds so much nicer than the micron I took off. And seems to pull harder.
http://imgur.com/a/Hm6bj
Niiiiiiiiiice!!!
Now that's live a healthy looking bike... live lactobacillus and all
There are currently 303 users browsing this thread. (0 members and 303 guests)
