Looking for some info on these besides what the internets give you.
I'm on Pirellis with a 180/60 rear at the moment and looking at the specs the width is much of a much-ness and the total diameter is smaller by 7mm (for the Dunlops 190/55). I understand again they are a cut variant of the slicks. Fronts are very similar in specs from what I can dig up.
Due to the different carcass and dimensions I would need to set up geometry and clickers on those bouncy bits.
Any idea on where I may start if I give these a try. It's the control tyre for ASC in the 600 class.
Are they a tall enough tyre not to run the spacer on the rear of the R6 shock?
