The bottom end is looking good so it's time to build it back up. First to fit up the gears then clean up all the sealing surfaces before applying gasket maker and new o-rings.
It's really important to have the goo in the right spots and away from the wrong spots. After a bit of squish, you can easily block an oil channel which would not be good at all.
Next to offer up the crankcase..
Then torque it all down to spec...
The oil pump, pickup and thermostat installed
Then the oil pan can go back on, along with the new magnetic sump plug. Getting closer!!
Next flip it onto the side and fit up the oil pump drivetrain
Followed by the water pump timing chain with sprockets, and new clutch assembly!!
Definitely looking better in here!
Next it's on with the case covers and GB protection
Flip to the other side, in goes the starter clutch and on goes the case cover and crash protection. Bottom end done!!
