If its hot enough for a sc1 rear you can probably use a sc0. Info I've been given and experienced myself is more grip and slightly more durable and not quite as sensitive to set up.
With the front. Most the faster riders don't use 1 or 2 due to heat or cold but which they prefer the feel for their set up or for a particular track. The different construction and compound makes them feel a bit different to each other.
