its really not that bad i don't think ill fix it as i cant be stuffed taking it off. Its just the shitty standard headers anyway.
As soon as i get the radiators back (most likely tomorrow) ill fit them back on and test fire the bike.
As it was running upside down for a little bit ill have to check the airbox for oil and remove the plugs.
Marshy- not sure if you do your valve checks yourself but do you know if you have to drop the motor to get easy access to the heads? Or just remove airbox and throttle bodies??
