Dont take such a long break that you need to worry about it?
So after my last day at the track it had been some time , approx 8 months since i last rode her . I had problem on the 2nd session with not reving out on one lap around 9k revs , then came good . possibly the fuel ?
Which prompted some talk in the garage as to what you do when you finish your last session and take her home .
1 - Fuel - finish the last session with as little fuel in the tank and wait till your out next before filling her up therefore not much fuel to go off and will mix with the new stuff when you top it up
or fill the tank up and reduce the amount of air in the tank to stop moisture and fuel going off . possibly drain it and refill it on the next track day .?
2- Coolant / water - Drain her after the last race meet and use coolant until your racing next . ? or just leave the distilled water in and hope its ok replacing it yearly?
3- Brakes - refreshing the fluid after xx months .
4- Oil and filter - wait until your out next and do it just before or change it after the track day and leave her with fresh stuff in her.
5- Anything else?
I don't usually have much fuel in the bike, but haven't had stale fuel issues when just topping up.
Coolant I haven't done either as the distilled water always comes out good. The Suzuki suffered a corroded welsh plug but the bike is 18 years old I don't think that happened in the last couple of years. I would probably use coolant of it was going to be a long storage time.
Brake bleeding is such a few minute job I do it most times pre track. So the fluid is always getting cycled and I do a proper full bleed and flush once a yearish.
My preference is a change of fluids prior, as oil still degrades with time sitting in the bike.
Leaving yourself wide open Mick
I'm all for coolant
With so many green machines Wetty how do you leave the fuel tanks , just as they are from track day to track day . ?
depends which . injected or carby ? most have no fuel in em , it usually goes in the scooter or the mower or the car or the blower/vac or the gokart
Good thread Rob, totally relevant to my next 3 months of London winter. I was thinking about all the things you mentioned couple weeks ago and decided on the following. If anyone knows for sure please inform!
1 - Fuel - Im thinking if i fill tank to the brim it will reduce ability for condensation/ice to build up inside tank...? obviously drain before next outing.
2- Coolant / water - definitely coolant for the cold
3- Brakes - refreshing the fluid just before next outing
4- Oil and filter - as above
5- Anything else? Butt plug to stop oxidising of cylinder (?)
Get out there and ride the fucking thing
Some good questions James ... hadn't considered ... google had some interesting answers ... I had not considered cardboard under the tyres.
PS good to have you back!
Just trying to help the fast get faster
There are currently 11 users browsing this thread. (0 members and 11 guests)
