I had a Yoyondyne slipper in my FZ1, I noticed it in my first session due to the lack of engine braking and lack of rear bouncing and skipping at the the hard braking corners, then never really noticed it since....which I take is a good thing :-)
Get the clutch plates stack height right and you'll be right ;-)
Edit
I just remembered the only problem I had was one of the spring bolts came loose and rubbed against the inside of the cover, a drop of blue loctite on each bolt fixed that.
