I got nuffin' but the bike seems to be hella stable!! Barely a wobble between 3/4 which is rare... Congrats!
Ok. So here's a vid from my best lap the other day. Lap 6 if you want to fast forward. Sorry, stuffed up the editing plus the sync is a little off with the data. And yes although wobbly the lap timer was secure.
So, what are the obvious areas for improvement. I know entry to T1 is an issue.
No need to be kind. Let me have it!
BTW, it's an 09' Blade.
Maybe there's an idea right there Ed. Maybe I'm not trying hard enough between 3 and 4.
That is one nice-handling motorcycle!! Very very smooth, and holds a very tight line with no effort, particularly through turn 1 and a few other turns. A couple of pointers:
1. You need a quickshifter. Really, you do. It will make a lot of difference to your ease of riding, and it'll cut your lap time. The time spent rolling off and on again, particularly down the straight (and the back straight) makes a big difference. The ride is much smoother too - no jerking forward-and-back on gear changes.
2. The forks are just a little too soft under brakes at T2 and T9. You're bottoming out, and that's why the tail wags. If you haven't changed it from Wade, that'll explain it. I'd add a couple of turns of preload, and a couple of clicks of comp to the front. You might need slightly heavier springs. I have a couple of questions I'll take offline (eg how much do you weigh).
3. Inconsistent apexing (eg wide on T2 on lap 6, tight on lap 7). When you get it right (eg T1, T5, T6, T8) it's tops, but you're too wide in T2 and T4.
4. Square off T12 just a teeny bit more, to maximise drive onto the straight.
5. Get a quickshifter. I know a guy....
I like all of this. ^^^
I spoke with Glenn Allerton. I was asking about how much the forks were compressing as the rubber marker was about two fingers width from the bottom. I had been told it should be about 1 finger from people obviously not in the know with the Blades. GA said that the Showa tubes physically stop about 12mm from the bottom so 2 fingers is in the ball park anyway. I had taken some comp off but after the chat with Glenn went back to where it was. Last session of the day less tail wag.
Frank Pons has set the bike up Nick and you're right. It's on rails. The way the rear Bridgey wears is text book.
I need to get comfortable using the rear to control the front lofting as well.
I do love this bike. it's a joy!
Thanks Nick. That's all solid advice.
And Nick, can you talk with this guy you know who knows a guy and pm me deets for the QS.
BTW I'm 80kg
Marcus, You might be able to use more of the track as opposed to riding in a lane. I notice you are in a 1/4 of the track where I would ideally have my knee over the ripple strip and tyres using all the road ( t4 for instance, double apex 2 to be close to the left on exit to open 3. T1 knee over ripple on the left and exit right out to the right , 9 also) . Riding edge to edge I think straightens it all out a bit . There is time there.
Yeh wow. Great advice Steve. I think I do similar to what you do Marcus. I will get a camera on this friday and go for some advice here too. Your bike is so settled mate! No advice from me, other than slow down! I want a 40. And a 39.
Firstly, you are faster than me so this isn't a criticism....
Given that the speed is accurate, actually in kph, and you are on a 1000, you should be getting to a higher top speed down the straight. (There are 600s getting to 270 down there in Supersport) That would be an easy win....right?
Lol zoid, follow me on the 6th for 40s and possibly lower! Krack, your exit of t4 is deep and it kills your speed around t5 as you are tight going into it. Really work on staying on the t4 curb and that will then open up t5 for you. Also t2 and t9 you had a wide line. Double apex t2 and get right on the last bit of curb for t9. T12 your apex is early which costs you time onto the straight. And like Marshy said, get a qs!!! makes it o so easy, i realised this when i rode the wet r6 without a working qs at asbk hahahaha
Copy that Carl! Slow down for a couple of laps and I'll try and see where you go. Quickshifter is on my list. If only i knew someone that knew a guy.
Do you get your ass all the way to the back of the bike under hard braking........ that might settle the rear under braking as i could see the rear moving around a bit into 2 and 9 for example and it upset your turn in. Other than that a few corners as has been mentioned already just need a little tidy and you will be really shifting like seriously quick !! ........ oh and get a quickshifter aye
hey your not the only one on used tyres !! i cant remember what the front has done and the rear is a used Marty gift
yeh but you're slow... it could have been worse, could have been my hand me downs!!!!! BAHAHHAHAHAHHA
anyone want a pain in da bum 21 year old puurlease get in touch
If you throw in his bike with the sale, I might be interested. Good fertiliser from young bones.
haha he dont have a bike !! ROFL hahahahahaha he borrows mine and his mums !!!!! hahahahahaha
No deal.
So I was mulling over all this great advice on the way home from work and and what I liked most was that all the suggestions are risk free. Mostly track position, setup ect. No body has said "brake later, accelerate harder, lean further". Essentially free speed if I can put most of it all together. Thanks TT gang.
Well you can add tuck in properly on the straight cause that top speed just doesn't add up! Hahaha
It's actually only 1/2 joke tbh, cause I see loads of ppl who just won't tuck behind the screen... could never understand race bikes with dark screens!
Dark screen + dark visor = zero vision.
Ummmm, I try to tuck behind the screen! Unfortunately my fat tum-tum gets in the way. Not that I'm quite in his league (yet) but I remember Philby Lovett telling me he was much quicker on the bike when he lost some weight. I wonder how much of it was getting more fully behind the screen?
I think a QS will show big improvements in top speed and also a sneaking suspicion I'm not using WOT. Top speed (260??) is only a bit higher than what I was getting on the old Suzuki.
I just punched all these suggestions into the optimum lap velociputer and I should be doing 1.28's.
Another thought is that you're gripping the bars too much under heavy braking. By trying to engage your core and/or grip the tank with your legs, you can relax your arms and let the bike do all the work. If you're putting weight on the bars ie. Arms are stiff to help stop your body sliding forward under heavy braking, then you're preventing the front from moving to compensate for the forces over braking etc. Resulting in that force being transferred to the rear, hence the rear moving around on you.
I've subscribe to this thread all good info on here.
Another fan of the QS here, and the quick Turn throttle
My speedo can show 286 and computime shows up to 294. Based on gearing commander the 286 speedo reading is correct. I have noticed an 8kph difference in top speed depending on how I come onto the straight. When you add it up around the track ie, top speeds, braking for turn 2 up to 240, into 4 190, into 6 190, into 11 over 200 your exit speed off the turns compounds pretty quickly. Like your exit out of 2 can have a +10kph difference at 4.
Sounds the same for me. I've only had one day with a GPS laptimer and I saw a maximum of 265 down the straight. My turn 11 to 12 sucks though, so hopefully I can fix that soon.
lol last time at asbk apparantly i was doing 270 i think it said... speedangle top speed ever was 252 (did it 3 times). I think there are a looooooooot of differing gps speeds around
i have no idea but i highly doubt i was cracking 270 down the straight.
At ASBK they had another box set up on the pit wall which I assumed to be the speed trap. it wasn't where you would expect it to be though, still well before the end of the grandstand where most bikes are pulling peak kph, but no where near the finish line. maybe it was an average speed setup but they got the distance wrong
If the computime times are out by close to 20kph then that is scandalous. Seriously. Those times go on the official record.
I'd believe Computime over Lean Dangle.....
1/10 of a difference from official timing to my Speedangle. So technically my best is a 1.40.9
Time wise there was a tenth difference between my gps data and the computime data. Speed wise, there was around 18kph difference every lap. Dunno what that means tho hahahha
Probably where the speed trap is set. Was listening to a podcast today about motogp top speeds at places like Mugello.
It's generally set for cars, their top speed is later as they brake later. IE; pedrosa had is top speed there at around 330, whereas he was well over 360. 360 km/h... bloody midget.
There are currently 26 users browsing this thread. (0 members and 26 guests)
