Page 2 of 4 FirstFirst 1234 LastLast
Results 51 to 100 of 180
Thread: Chubb's new steed
  1. #51
    There you go..
  2. #52
    Chubb's new steed
    Cheers Baddie. I will look at making something up.
    This will have to do for the time being though.
    Hid the fuse box and some wiring under the airbox so everything looks neater.
    Also put the wheel so that it is rotating in the right direction. Previous muppet had it in the wrong direction (with the wheel sensor on the right not left)!! Even more puzzling why Kawasaki didn't design it such that the wheel only fits in the one direction! All sorted now though.
  3. #53
    Put some block offs and removed the pair system.
    The block offs that I had on the R6 fit straight on.
  4. #54
    Nice one Chubb, bugger of a job bit needs to be done before tune.
    Just add cap over bottom of air box whole, and job done
  5. #55
    Oh, does it still have the flap on the intake ram tube?
    If so that can be easily removed
  6. #56
    Chubb's new steed
    Getting some Dyno love next Tuesday.
    Does anyone know about getting another key cut? I got the little tag on the key but no red key. Does Kawasaki still have red key?
  7. #57
    Can't they just remove immobilizer when you get it dynoed so normal cut key would work? Works on R6 ... otherwise copy of key without the master costs $250.
  8. #58
    Not on zx6r. ..lose red key you need nu ecu.. expect the 10 to be the same. You can remove barrel and put it under the tank and wire a switch in line.. leave key in on position. ..
  9. #59
    Worth a call ... ???
    http://www.innerwestsecurity.com/inw...utomotive.aspx
    We can supply new keys even if you have lost your Kawasaki RED Master Key.
    We can supply new keys even if you have lost all your existing Kawasaki keys.
    If you do not live locally give us a call we have options available.
  10. #60
    Worth a call for pricing at least
  11. #61
    Preddy's locksmiths in Miranda (top locksmith IMHO, do the advanced stuff) advised me of the price $250 odd for one R6 copy ... I believe it's the same technique they use to copy the other electronic keys. From memory they can't create a new red from a black, only clone blacks.
  12. #62
    Probably could flash out the immobiliser I think.
  13. #63
    This,
    Had to do it on the Gixxer after my key shit itself.
    I used flash-tune
  14. #64
    Mounted the lap timer.
    Ideally I want it closer to the triple clamps but will have to make up a bracket. Gonna see how it is in this position first.
  15. #65
    Those speed angles are a nice bit of kit. Looks quite neat where you have it now.
  16. #66
    you won't see it there, it will be under your chin, you'll need it near your guages
  17. #67
    Chubb's new steed
    I was gonna make a bracket for it to sit just behind the steering damper. This position will have to do till I get around it. It's only velcro'd down at the moment.
    I probably will still run the wire under the tank somehow. I think...
  18. #68
    I made a bracket up to mount just above steering damper, but did play with the idea to mount where you did also.
  19. #69
    Cheers Lee
  20. #70
    Get a RAM mount. Fix the base to the inside of your top faring, to left or right, whichever you prefer.
    Mine sits where the red circle is on the pic. rock solid. Doesn't have to be moved. Surprisingly easy to glance across and see.
    you're talking about 30-45 degree's of difference in vision to look down and see that position when you're on track.
    I tried it at one stage. Felt miles away.
    Thats me.....
  21. #71
    Mine's similar mount to Jamie's (thanks Bob)
  22. #72
    I used some angle from bunnings that I whacked with a mallet in a vice to get the right bend
    (Now sits closer to tach)
  23. #73
    wow what a mess Rancell. the scratches on the fuel cap had to be the 1st reason not to go ahead with the purchase???????? and the rest of it , how the fuk does someone actually turn up to the track with such an ill prepared %^&*(@. and the reg rec placement ??? and what if you have a fuse pop , how long will it take to fault find?
    Cliffy you got a dream ride and a bargain?
  24. #74
    its a top idea to be able to run them both ways , buy another chopper plate and then you will never make a mistake like some have. If you rode it round the block the dash would have told you it was in backwards
    old owner obviously just threw it in to sell
  25. #75
    Quote Originally Posted by WETTY View Post
    Slowly slowly getting everything to be in the right position.. thats why we post up so we can get feedback and advice.. how else to learn
  26. #76
    Get rid of that weighty ignition barrel.. must be slowing you down heaps
  27. #77
    Not having a dig at you Rancell
    Just the way some/most? Prepare or don't prepare there bikes
    No pride anymore
    No pride = I don't give a shit if I bin it = that 1 you don't want to grid up together with .
  28. #78
    That's why I pulled apart the bike and am checking everything before I go out on a trackday. I don't want to be one of those people who delays everyone's track time and money with spilt coolant/oil etc
  29. #79
    It's a real shame 1 can't trust anyone anymore when buying 2nd hand bikes
  30. #80
    Let me know if you want me to knock up a CF Bracket for your Reg/Rec.
  31. #81
    Sexy!
    Ow much? the R1 has the reg rec in the same spot
  32. #82
    Will let you know.. 6 pack?
  33. #83
    Quote Originally Posted by Negrogrande View Post
    Sexy!
    Are you at the Creek first week of Jan ? If so, we'll measure it up.
    I think i've got a few sheets of 3mm left.
    Make a donation of over $30 to the Cancer council of NSW, that'll cover it.
    http://www.cancercouncil.com.au/about-us/
  34. #84
    Hey Jamie... I'll be there on the 4th if you are
  35. #85
    I think so mate. I just need to get off my arse and finish glassing, bogging and priming my fairings.
    Aiming for 2,3,4 still at this stage.
  36. #86
    I'm there on the 3rd
  37. #87
    http://www.ostanlock.com.au/Motorcyc...melbourne.html
  38. #88
    Mock up... Better spot I think!
    Carl got some carbon wrap left over???
  39. #89
    looks better. Tested with your helmet on in a tuck?
  40. #90
    Yeh that's gunna get they on a ride day
    You shooda kept that dash u sold
  41. #91
    yeh works well now with helmet in tuck position..
    they close one eye... especially with big Rob workin...
  42. #92
    Mini rob
    Big rob wouldn't lower himself
  43. #93
    Hey I've got a copyright on the "smaller" descriptions
  44. #94
    Sorry
    Mid sized rob then
    Fark I thort he was Leanne's bitch
  45. #95
    Got myself one of these on the way. From where the poms live
    replace the stock hanger with footpeg bits sticking out.
    Also looking at some of those captive wheel spacers. You still got em wet one?
  46. #96
    Shoulda gone the evotech hanger
    Yeh almost out
    Let me know how many you want before Sunday nite
  47. #97
    Faaark the power of the 10R! Rip my arms out everytime you wind on the throttle!
    Very fun bike and very quick. Rider not so much. Still have it in pussy mode.
    A false neutral during one of the sessions but that's because I was a numpty and didn't put a positive push on the gear lever. Think will have to adjust the gear shift lever and make it slightly higher.
    Overall very fun bike! Will have to do more setup and have plenty of seat time I think.
  48. #98
    Yieeewww!! Awesome mate....
    What else do you need/want to do, setup wise?
  49. #99
    Well done chubb , good to see mate.
  50. #100
    That's a excellent result Chubb. 39's is my long long term goal. First time out, you got to be happy with that!
