Replaced the old, smashed fuel tank bracket with a shiny new one from Yamaha!
The front end smash left me without intake temp and pressure sensors so I had to find some new ones... Checking the wiring here.
Then re-terminated, no error codes so - good to go!
Next to make a custom, progressive quick throttle from some old PVC pipe. If you've not seen it done before, here's how it works:
First I had to cut out a section of the PVC pipe...
... then glue it to the throttle tube...
then a smaller section on top, glue that down...
then dremel to the required thottle delivery cam shape. In this case, the standard amount of throttle when cracked, to help avoid accidental high sides, then progressively getting more aggressive after that...
Dremmel a wee slot for the throttle cable. This part will actually make it less snatchy than the oem throttle when first cracked...
Nibbler on the assembly to allow for the new shape...
before putting it all back together....
Chucked on some new levers...
Fitted a new racing front reservoir and bracket...
It's not a Honda but damn, I love the HRC rear reservoir tube... fitted.
Scratching around for things to put on now! Probs off for a flash and dyno soon...
