Just order from HEL Australia. The brake line for an RSV4 needs to be 1300mm, if you are keeping the footbrake. You need to get a 45 degree banjo on one end, and a straight banjo on the other. You also need to order THREE single Brembo-sized banjo bolts.
Dean at HEL did ours overnight. Easy and cheap. There's a wide range of colours too.
You will also need a reservoir, some tubing and a mounting bracket. We can supply all those too.
