It should be sweet, The two bolts that are in there are bottomed out in the bracket and loose in the countersink to allow the chain to be tightened and loctited in with the heads covered by the washer of the axle nut. Fast Frank makes a bracket for $150 US or $480 US including Lightech adjusters but where does it end. I put captive wheel spacers in and will make up a bracket to hold the chain out of the way and a ramp so the wheel can be pushed forward to remove the chain and then roll out and down at the same time to clear the sensor . I mocked it all up yesterday and its pretty sweet.
