Originally Posted by
Carl-52
Dlc (Diamond like Coating) is a material chemically bonded to the surface of the piece you are working that fills imperfections and cracks and makes a "perfect" surface with reduced friction, means it makes stuff slippy, less friction = less heat= less power loss= less wear on parts. superfinishing is the process of machining and post machine work to a near perfect surface without chemical adjusment. This helps to reduce crack propagation, etc and does teh same kinda things as dlc, less friction = less heat= less power loss= less wear on parts. But this also helps gear meshing and oil drag etc. Both very expensive processes to get done. The other one is cryogenic processing the components. < that one makes dlc and superfinishing look cheap.
