oh true? I'm having difficulty figuring out if I need to dremel the housing or not.. I don't think I do because it fits and moves as it should. Only thing I think I need to do is loosen the cable at the throttle body because the only way throttle snaps back is if the adjuster is wound all the way in at the handlebar.
