Quote Originally Posted by WRCPUG View Post
thanks guys its getting there.
Nick- got a question for you. Where do you mount your Reg rectifier on the RSV4's. In road trim its attached to a plastic shroud that sits behind the fairings but not sure if that will fit with the race fairings.
Do you have any photos of your set ups? Also thanks for the advice on curvey girl...i ended up getting my pads and Brembo repair kit through them.
Also i had this guy Jason just pick up my old track bike this morning, i mentioned that he should look at the Annitori QS for it. I think he ended up buying it from you. Hes based in NSW so you might see that black blade out at SMPT some time.
Good stuff mate
Here's where I put my reg/rec. Some guys run them up under the dash area, but here works too.
